I am adding an immersion heater into the house i am doing up.
Its place in the consumer box is the 16amp (no rcd side of the spilt load).
At the heater end of the cable (USED 2.5MM), i have a timer to go in, a heater switch with neon idicator and the new immersion heater itself (it is the new cut out design).
Do i need to put a fused output at the immersion end or will the consumer box deal with that with its 16amp?
IF i need a fused connection at the heater end, i will need to find myself a fused switched then.
Many thanks,
Stuart
Many thanks,
Stuart
