- Joined
- 7 Mar 2004
- Messages
- 284
- Reaction score
- 4
- Country
I'm just about to install my extractor chimney. It's the type which can recirculate using carbon filters or extract to an outside vent. Obviously the best option is the latter as I have access to the outside wall. Unfortunately, the installation instructions just say that I will need to buy an additional kit for the venting, which I guess means the tubing, and the external vent.
So, please tell me if I've got this right:
I can use the cooker hood kit (or similar) available from Screwfix:
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=13076&ts=51403
This has the metal hose as opposed to the plastic stuff - which is not recommended for installation in a chimney extractor and to the outside vent surely?
I then need to drill a hole in the wall that's at least 100mm wide for the hose so I can use a 110mm TCT core drill for this?
Is there anything else I need to consider?
