Fitting letterbox to uPVC door or wall
2 Apr 2008
Hampshire
Hi folks,
I have a uPVC porch - basically a mini conservatory - which I have to leave unlocked because there's no letterbox on the outside. I'd like to install a letterbox either in the door, or in the "wall" next to it.
The door has a glass panel top and bottom with a uPVC beam across the middle. The "wall" is the same - glass top and bottom with a beam across the middle.
I believe the construction however is that there are metal frames inside these centre beams so I won't just be able to jigsaw through. (I drilled a small test hole into the wall and certainly it hit something hard. I don't want to test-drill the door.)
How does one fit a letterbox to a door/wall like this please?
Thanks,
Mark
