Fitting metal ceiling rose light fitting.
10 Dec 2009
Derbyshire
hi. I have brought a light fitting with a metal ceiling rose. The cables coming out of the ceiling are 2 black with copper unsheathed wire coming out of grey sheath and one red wire coming out of grey sheath. am I right in thinking the 2 blacks are live the unsheathed are earth and the red is neutral??
Next my light fitting has a red which is live? blue which is neutral? and green/yellow which is earthed?
I've got a connection block sorted but I've been reading that the rose being metal needs to be earthed. does that mean I connect the green yellow with the two unsheathed cables or does it mean I actually connect the earth to the ceiling rose?? can anyone shead some light on the situation? (terrible pun i know)
I think a picture of the wiring from the ceiling will clarify what you mean.
How are(were) those cables connected in the existing light?
Do make a note BEFORE you disconnect anything!
The two blacks will be neutral. The red will be live.
The new light fitting will need earthing if it isnt double insulated. It will say so in the instructions.
Red and blue sounds like an odd combination in the light. Thats two different colour codes. Sure its not brown and blue?
