Fitting my doors
27 Jun 2009
Nottinghamshire
I've just recently bought a 2nd hand integrated fridge freezer and I'm stuggling to work out how the wooden door (unit door) attaches to the fridge.
Here's a photo......
I've screwed the fridge bracket to the fridge (as you can see in the photo) but then surely the small piece that screws to the wooden door has to slide along the fridge in order for it to open? Any ideas suggestions or something any of you have seen before. (It's a Kuppersbusch fridge freezer by the way but the brackets are apparently similar to a bosch)
Cheers
it looks like the bracket you are holding fits underneath the screw you have on the bracket attached to the fridge door.
i dont think it has to slide
screw the piece you are holding, to the wooden unit door, and then undo the screw on the fridge door until you can slide the bracket under it and then tighten
You mean the bracket I'm holding, the part that sticks out need to screw onto the fride door? (the hole with the slit in it point towards the camera?)
Cheers
