I need to fit a neon indicator switch in place of an ordinary light switch. Unfortunately there is only one wire to and from the switch (plus an earth).
The new switch is a double pole switch with the neon wired across the two bottom terminals.
I understand that I also need a "neutral" wire to make it work properly.
Where do I find a neutral wire?
How do I wire up the switch?
Frengineer.
Did you manage to resolve this issue ?
I have a similar problem, whereby I have a switch that incorporates a neon light which I need to use in place of a standard existing switch to my bathroom.
The new switch has 2 outer brass connection points, at the top with one either side.
Immediately below are 2 central connection points, one marked L2 and the other N2.
Below and in line with these are 2 more connection points, one marked L1 and the other N1.
I only have one black and one red wire incoming into the switch.
Any assistance on what goes to where would be appreciated please.
Best Wishes
ADG3
