- Joined
- 13 Mar 2021
- Messages
- 4
- Reaction score
- 0
- Country
Hello. I wonder if I could ask for some advice please. I need to replace an old imperial sized bath that is installed in a recess between two brick walls measuring 1665cm. We need to install a shower bath that is available in 1600cm and 1700cm. I have a couple of quotes to do the work. One suggests using the larger bath and cutting the ends in to the walls each side of the recess. The other said this is a bad idea and he would fit the 1600 with a fill in section one side. I just wondered if it is usual to cut a larger bath into the wall or whether the smaller bath would be the usual way of doing it. Thank you.
