fitting new electric hob
13 Jan 2013
Manchester
hi there i previously has gas oven/hob just bought new elec oven/hob but the oven came with flex/plus on the oven to plug in, but the hob did not have anything, can i just fit a wire/plug to it and plug in or does it have to be wired inti the fuse-box
thank you
No, you must follow the manufacturers instruction or IEE wiring requirements if instruction do not detail.
The output power of the hob would be required, to calculate what flex, cables, fuse are safe to be used to supply the hob.
You have already posted this question rightly on Electrics UK forum, if you give the details asked for, then help/advise can be offered.
There is no need to duplicate your post here, all the relevant information will be given on the Electric UK forum, as that is where you will find the knowledge.
