I have removed an old kinackered shower tray. It measures 740 x 740mm. Having read a few old threads, I can assure you that it is 740mm. The available space measures 760 x 760mm. Not being able to find a 740mm shower tray, I thought I'd fit a 760mm. Found one on eBay but its states that "Overall External Dimensions 778 x 778mm" .
So.. how can a 760mm tray measure 778mm? The side appear to be perfectly vertical, not sloped, and that is the case with all other trays I've seen.
Is 760mm just a guide, and will different makes and styles be different sizes? If that's the case, its a bit of a risk being one without seeing it and measuring it (unless of course space isn't an issue).
My three walls are in place, so size is an issue. I'm thinking of buying a 700x700 tray I've seen. Yes, its tiny, but there will still be the same elbow room. Is there any reason not to do this? I'll have to make a wood frame and tile it , but I'll have to do that anyway (the actual shower room is quite a bit wider).
The 'frame' that I've removed from around the old tray was tiled directly onto the wood. Is this OK to do?
Any other hints or comments?
