Fitting oak skirting - screw, plug, then apply finish?
6 Oct 2009
Lancashire
Hi all,
If I'm fitting oak skirting, and I screw and plug them, does this mean that I'll have to finish them after they're on the wall? I'm guessing that the process is:
1. Cut the boards to size
2. Sand and stain the boards
3. Drill the screw holes
4. Screw the boards to the wall
5. Cut the plugs from similarly-patterned and stained board offcuts
6. Glue in the plugs
7. Sand the plugs flush
8. Apply varnish / oil to whole board
Is that right?
Thanks all,
Russ :)
You could finish them if using oil , then fit and plug, cut of plug with a flush saw to minimise sanding as that may mark surrounding area.
Personally, I'd cut the boards to size,
Sand the boards,
Fix to wall,
Plug the screw holes,
Re-sand,
Stain,
Varnish/ Oil,
Go to pub,
Enjoy.
