AILEEN WATERFALL BATHROOM BASIN MIXER TAP W-01
Could anyone please give advise on fitting this monster! I fitted but have a leak that must be coming down the thread off the tail.
When you screw the tails into the monoblock do you go finger tight and then pinch it a bit more?
Where should the black o rings be during this process? Do they screwed into the thread/ ('cos thats what happened!)
The horseshoe clamp and washer does not seem to fit around the tails as the part of the tails visible when fed throught the sink hole is the fattest bit.
And finally they supply an o ring to seal the tap to the sink, this is so awkward to keep in place, could I replace with a proper washer?
Any advise very welcome.(including throwing it on the tip!)Thanks
