Hi. I fitting plasterboard in the bathroom. Ceiling and some of the walls done.
Included a picture, so saves having to explain everything.
I want to know if I should fit the board all the way up to the windows or to just fit to half the joint. I assume if I want to tile eventually I need to fit it up close to the window and use noggins for the next boards?
Do I cut and fit wood, to fit inside the the window opening? Before I tile over this? If so do I just use standard bathroom sealant between the plasterboard and wood?
The window is 1200mm x 1200mm.
