fitting pumped showers
12 May 2011
Middlesbrough
I have been asked to fit a pump to 2 showers in separate rooms both fed by cold from separate tanks in the loft one each the hot feed is coming in from below the bed room floor is it possible to fit on pump to do both showers :confused:
Yes if they have common supply pipes.
You would need to have a dedicated hot and cold to the pump, then a feed to both showers from the pump.
You should also consider the size of the storage water feeding the pump and increase as necessary.
