Fitting Room Thermostat
17 Nov 2004
I am thinking of fitting a room thermostat.
My boiler is a Sime Halstead Trio combi, which controls the CH temp by a knob on the panel. I think this is playing up. Hence a room thermostat.
Any advice on fitting one would be great please.
I presume a simple thermostat is a straight switch in the "on" signal to the burner. So all I need to do is track down the relevant wire, check voltage and break in with the thermostat.
Am I right?
Thanks for that swift bit of help.
I'll be having a good look tomorrow, when the family are out and the heating will be off.
Just had a quick look.
Think I've found the correct terminal block.
However there is no straight link.
The block has 5 terminals.
The first 2 are live & neutral 240 Volts which go into a connector on the PCB. The next is an earth.
The next 2 terminals are what I'm after but they don't look directly linked.
They are marked with a diagram showing they should be switched, and marked:-
"TERM.AMB.-ROOM STAT"
THERMOSTAT AMBIANCE
Both have a red wire going off to another connector on the pcb, and one of these terminals also has a wire connected that is one side of the timer on/off switch.
Any ideas as to how I connect a room stat to this?
It's a built in timer.
The boiler is a combi, all controls are on the front panel.
A timer, and timer on/off switch, a switch for summer/winter (basically CH on/off), a heating temp control knob, a hot water temp control knob, and a gauge showing water temp & pressure.
Call that number and she will wisper sweet nothings into your ear.
Kevin, the man wants to fit a thermostat because boiler stat is broken. I cannot see how the boiler is going to work with malfunctioning boiler stat
Halstead have kindly sent me a copy of the fitting instructions, which includes wiring diagrams. :LOL:
I can now see how it all works.
Am I right in thinking the CH thermistor is a thermocouple which the contol board uses to monitor the temperature of the water in the CH. Is there any way to verify this is working correctly.
The problem I have been having is intermittent, which always makes a fault difficult to trace.
