Fitting RSJ in load bearing wall !
11 Aug 2013
Liverpool
I have fitted an 8"x4" by 2.5 RSJ going between kitchen and back living room. I have a 60mm gap from top of beam to bottom of joists. How can I pack this out ?? Thanks
Length of 60mm wood ? Why not jack the beam up onto the underside of the joists and pack up the end points with suitable footing
I have a stone post at one end stopping me from going right up to the joist. Would a piece of timber comply with regulations would you know ?
Couldn't you cut a bit of the stone post away so that you can get the beam up to the joists.
I've never come across it in this situation, so not sure what building control's reaction would be, but there is not reason structurally why you shouldn't use a length of 100x63 joist above the beam.
If the existing joists are not overstressed in bearing, then the additional timber won't be either. It's obviously internal so no issue with water ingress either.
