fitting speaker to galaxy
26 Jul 2008
Antrim
im having trouble making a kinetic speaker work on a galaxy 500 panel. when i put the wires in the horn connections nothing happens, or when i put them in an output same again. any ideas please?
you need to have a 16 ohm speaker connected to the two terminals marked as a speaker.
all other outputs only switch voltage.
if you go to outputs (53) yes there is an option to change it to horn (speaker) but all that does is change state when ever the speaker operates
