Last night I found I couldnt unlock the back door, the key operated but the unlocking mechanism wasnt.
Much misery and cursing.
I managed to get the door out this morning by removing the glazing and the hinge pins, prising open a gap to reveal the two security pegs that locate into the hinge jam, then cutting them off with a hacksaw blade.
My problem now is refitting the beadings.
There is a white rubber bead on the inside and simple upvc beads on the outside.
Can any experts out there advise the process of refitting - ie whether you put the rubbers in before the external beads, or vice versa, or any other order?
I find whenever I try to fit the side bead, it pushes the top and bottom beads out of place slightly. It's really p***ing me off.
Thanks for any tips!
