- Joined
- 11 Apr 2016
- Messages
- 6
- Reaction score
- 0
- Country
Hi guys!
I decided to brave it and change my bathroom tap.
Things were going rather well (managed to remove old tap and drain fine). But now I am stuck with two problems.
Firstly the hot and cold water outlets from the wall are quite far below the sink which means the 300mm flexi tap connectors do not fit. The flexi connectors from the old tap seem to be 500mm but those too are just about fitting if I turn them at a very sharp angle and besides they are rusty so not too keen on using them.
Question1:
Should I just get longer flexi tap connectors? I could not find anything beyond 300mm at screwfix, toolstation, b&q and selco. Any ideas or maybe I was just searching incorrectly.
Alternatively is there anyway to extend stuff. On the wall side I have what looks like a pushfit connector with a screw bit that I used to isolate the water (and a ball on the inside).
Question 2:
I replaced the drain too. The seal on the top of the sink seems fine i.e. I shut the drain cover and water stayed there without leaking so seemed ok. However when I allow the water to flow through it seems to leak out a lot from the side of the seal the bottom of the sink.
What should I do? Should I use silicon for a better seal?
For more context on the bottom side there is a black rubber bit, then a harder white bit and then a large black locking nut.
The tap I and drain plug I am trying to install is this one if that helps.
https://www.toolstation.com/deva-ethos-taps/p22723
Question1:
Question 2:
