I need to fit a tee into existing pipework which has no scope for movement along its axis. I propose to cut the pipe pull it to one side and slide the tee fully on at one cut end, cut the the other piece of pipe level with the other end of the tee and then slide the tee over the cut pipe and then tighten everything up. I estimate that this will give a 6mm length of pipe past the olive on each pipe. Anyone have any doubts about this rational or have done similar in the past. Cheers for any thoughts,
