Fitting / Tiling a bathroom
18 Jul 2006
Hi Guys,
We are getting a new bathroom fiited shortly and have got a plumber to install the bathroom for £200, which is all fine and dandy.
But, I will need to do the tiling myself. I have read lots of tips about tiling like stating on the wall directly infornt of you when you enter the bathroom and also begin tiling in the middle of the wall and work outwards.
However, when do you start the tiling? Do you firstly remove the old bath, toilet & sink then remove the old tiles, re-tile and then fit the new bathroom? Or do you fit the new bathroom first and then tile around the bath/sink/toilet?
Is there any perticular order?
Cpt_Damage
remove everything and re-plaster. keep the old toilet for possible temporary re-use.
fit the bath and silicone seal to the plaster once dry. don't forget to allow for bath panel clearance.
offer in the new ware and complete any alterations that need doing to the waste and feed pipes, allowing for any floor covering. put isolators on the feed pipes and remove the ware.
tile the walls and apply floor covering if applicable.
double seal the bath to the wall tiles and re-fix suite.
