My house was built about year 2000, i have 9 radiators which use plastic pipes rather than copper, I'm guessing 10mm definatly not 15mm.
It is a traditional system - not a combi ,I'm thinking of fitting TRV's to the rads.
Would I need a different kind of TRV because of the plastic pipes ? I was thinking of these ones http://www.toolstation.com/shop/Hea...tic+Radiator+Valve+10+15mm/d230/sd2762/p80954
I've heard I'll need some inserts Is this the kinda thing I need http://www.toolstation.com/shop/Plumbing/Pushfit/Pipe+Inserts+10mm/d20/sd3143/p96609
Wouldn't the pipe already have inserts in for the current fitting ?
Are the Speedfit inserts different to what I require ?
I've felt both pipes to determine which is the flow/return - Is it normal for the flow to be on different sides on different rads ? ( I know that with most TRV's now it doesn't matter which side they go on) I am right in thinking that aren't I ? I will try and fit on the flow side though.
I tried to balance my system a while back which i feel was a success so I have some return sides not fully open - Would it be OK to open these fully once the TRV's are fitted ?
Sorry for all the questions and i hope they not too confusing - Thanks for any replies
