Last year a British gas engineer fitted 2 new rads for me, both have TRVs on the return end. I would assume from what I've read that these are bi-directional TRVs.
I want to fit TRVs to the other rads in the house as it's been hard to balance and I think this might help, plus it sounds like best practice.
With the new rads I've found I have to open the flow valve a fair bit before the flow pipe even gets hot. If I fitted TRVs to The other rads in the house, what would be the key to balancing the rads? By adjusting the flow, or the thermostat return? If it's just a matter of adjusting the flow that's great. And to confirm, the TRV will do as good a job controlling the heat fitted to the return as to the flow?
Many thanks
Many thanks
