My daughters house has a fortic tank in the loft , not very efficient, the only other option is to use a heat store,this could be fitted in the single storied utility/boiler room ajoined the house but the existing pump is in the flow on the landing/corridor with feed/expansion pipes on the boiler side of the pump.
if the pump is moved to the boiler house, then the feed and expansion would also have to be moved , a really major operation.
can I just put an additional pump (with appropriate controls)in the boiler house to feed the heat store coil or alternatively move the pump to the return pipe ?
