fitting two way valve on gravity fed system
3 Feb 2012
hi all having to fit hot water cylinder thermostat to my heating system was hoping someone could gives us a bit of help :eek: on how to wire in the two way valve that needs to go in / my system is gravity fed and the boiler is a old ideal standard with a HORSTMANN 425 TIARA PROGRAMMER fitted so how do i go about it cheers :)
Interlock screws will be in the back of programmer (full control) , or are you asking how to wire a C plan? , motor valve should have an auxilary switch (white wire).
Valve should be fitted so as not to interupt cold feed ex/OV path. :D
I hope you know what position in the gravity circuit that valve is supposed to go.
thanxs gaswizzard would be the c plan been fitted was confused where to make the joint on cold feed close to boiler or cylinder and where the wire from two way valve is to be fitted is it the timer programmer or somewhere else :confused: cheers
