I am planning on buying a UPVC french door and a patio door and fitting them myself. I have fitted UPVC windows in the past but not doors before. I am assuming that the procedure is similar.
I noted that elsewhere on this forum it was said that usually only the sides of the door frame need be fixed with anchors/screws. Is this correct?
The windows I have fitted have been narrow enough that it wasn't necessary to secure the top and bottom. But with a 2m wide door this would surely leave some play in the top and bottom of the frame. What is to stop the frame deforming if it is accidentally kicked? (or deliberately kicked by a burglar from outside).
Is there anything else to do with fitting doors that is different to windows?
