M
marsaday
I am fitting 2 velux today sat side by side. The gap between the two is 100mm.
The brackets actually touch almost (at top and bottom) and the gap is now 108mm. The metal brackets are actually adding an extra 4mm to each window, which adds up to an extra 8mm between the two?
Does this difference matter and do i need to get it spot on at 100mm. If so i will need to chisel out where the brackets contact with the dividing rafter.
