Fitting w.c
H
hav it
hi all im looking for a solution to remove a toilet and cystern and fit a close couple toilet The only problem is the waste drops down right at the back of the pan in the floor. so if i was to fit a close couple at present the pan would sit over the current waste hole in the floor.
You will need to fit some packing behind. A box of some sort.
is there no way i could move the drain hole back
yes the pipe can be moved, however it is not a job to be taken on lightly, and can turn into a disaster, the easy solution is to buy a bent multikwik and fit the new bowl and cistern, then build a box behind the cistern to create a small bulkhead, there is a swan neck bent multi available which will kick the cistern back a bit, you need to measure the new cistern, the pipe distance from the wall and the 2 multis to see what can be done
Beep-beep ;) If it`s on a wooden floor with a void under :idea: you might be ok -solid floor no chance
looks like i will have to build a box at the back or fit a new one with flush pipe.
do they not make a close couple toilet to fit i.e with the cystern set back.
