Not fitted windows before, but have some to do in the next few weeks. These are aluminium windows going in a mix of lead covered dormer and cedral clad wooden framing.
In my head I was going to use silicone around the opening as the windows go in for the frame face to but up to, then get up my scaffold to seal again from the outside with more silicone. But then I figured I should find out how it's done properly, did some Googling and came across EPDM rubber tape seals.
I've not really found a definitive answer as most of the search results are for fitting in the reveal rather than behind the reveal.
So, hows it done properly? If I use a tape seal, can I fit these to the check reveal before the window goes in and avoid having to setup my scaffold to seal these from the outside afterwards? If so what's the best tapes to use?
Thanks!
Thanks!
