- Joined
- 11 Sep 2007
- Messages
- 769
- Reaction score
- 31
- Country
Hi guys,
Need to fit a wooden bath panel to a bath just fitted and cant for the life of me work out how to fit it! Hoping you guys can help
have attached an image of the brackets supplied with the panel, there are three of each bracket, the two on the left are the same as with the two on the right, just different angles!
View media item 2374
The panel is in two parts, main panel and plinth to allow for different heights, I assume the plinth goes behind the main panel and screws through from behind once the height has been measured?
My main problem is fixing this to the bath, I just cant work it out, No real instructions either
Hoping you can advise which bracket goes where and how if fixes to the panel and bath? I also assume that I will need a baton on the floor for the plinth to sit up against?
There is no lip on the main panel at all, so cant slot under the bath as a plastic one would, the panel is about 12mm thick.
Really hope you can help as this is driving me nuts!!!!
Many thanks
Many thanks
