I feel a bit thick having bought a very expensive valve.....
I have a Hansgrohe ibox universal valve for my new shower. The inlet/outlet ports look like they can either be 22mm or 15mm fittings (there are reducing nuts supplied for the latter). In either case, there is an internal thread to connect in to.
QUESTION IS: What end fittings do I use to connect to the (threaded) ports?
Do I dismantle one end of a compression fitting and screw it in with some PTFE tape? If so, do you leave the olive in place or discard it?
Or is there some kind of specialist adapter/fitting?
