Hi All
Got a major leak on a 22-15-15 tee, solder joint failed. I have placed some Fernox LS-X and PTFE to hold the water, but still leaks under pressure. The joint is below floor level and will be difficult to drain.
I'm not confident to carry this repair out. Can someone give me an idea on cost to repair? There does not seem to be enough room for a compression fitting and a soldered joint looks difficult!
Thanks in advance
Pete
Thanks in advance
Pete
