When I close the front door a small gap is noticeable at the side on the bottom half of the door. With the recent cold snap you can clearly feel a draught coming through. If I push my foot up against the door this stops the draught.
The top part of the door seems to be ok as you can't feel a draught there.
Do I need to adjust the hinges with an allen key to fix this? Also is this easy to do as I've read on some forums that it can be quite difficult if you're a novice which I am?
