Please can someone give me some advice on whether to fix the problem with my old boiler or replace the it entirely.
I have a Vokera Excell 80SP. Since the start of the week, the hot water supply stopped being heated up when I turn the hot water tap on. It starts initially warm for a few seconds and then is cold from then on. The central heating works fine and fires up as the timer controls. There is no hot water even when the boiler is firing for the central heating. I was told that if you had heating then it would heat the hot water anyway.
I have been living in the house for 9 years and have serviced the boiler regularly. I can think of nothing that has happened to cause this fault except the boiler is quite old. Last year (18 months ago) I had the same problem with the hot water not comming on but the engineer replaced the part with a new one and it worked fine since then. I can not remember the part that was replaced nor find the receipt.
As my finances are tight, I would prefer to fix the problem but not if it costs a couple of hundred pounds that could go towards a new boiler.
Can anybody suggest what the problem is and approximately how much it will cost to fix?
I have been reading a lot about the Vaillant ecoTech 831 as a replacement. I am in a 2-bed semi with one bathroom.
Many thanks in advance.
