Hello all,
I think this tap is a reverse pressure one and it has a very low flow. This is the advice from an article on this site..
I can get the central barrel out (I pressume thats what called the body above), but am a bit confused by the rest of the instructions. What comes out is a reverse threaded thing with an o ring on it - is this the thing that needs 'banging' to dismantle. It doesnt appear big enough for a washer or anything (But I'll look again tonight)
There dosnt appear to be anything else to dismantle on the tap itself - this is what it looks like (sorry about source of piccy!)
Tap
Any advice?
James
.Removing the body
* Undo the nut above the body of the tap.
* Once this is done the body can be removed by undoing the tap as if you were turning the tap on.
* Don't be alarmed by the water that runs, keep unscrewing the body until it comes off.
* When the body is removed the internal check valve will operate to stop the water.
Replacing the washer
* By banging the nozzle of the body empty out the inner workings of the tap.
* Bang the nozzle of the body to loosen the inside.
* Once the inside is loose it can be emptied out to reveal the washer.
* Prise the washer off with a screwdriver and replace.
Finally
* Reassemble the tap in reverse order.
Tap
Any advice?
James
