Fixing a baton to a plaster wall
15 Jul 2012
Wiltshire
Hello
Hopefully this is a simple question to answer - its just not one I've seen asked :)
I need to tile a splash back around the bath of a house I'm buying. It's a 1930s house with brick/plaster walls. I've researched how to tile and I'm looking forward to learning as I go. However one thing I've not been able to confirm is how I can fix my guide batons to the plaster wall.
Plaster is hard so I assume that I'd need to drill, plug and screw the batons on, but for something so temporary will nails work?
I'd rather get advice before I find out the hard way ;)
Thanks for your help
tempranello
Masonry nails may be ok for the job, 3 inch preferably and don't hit them all the way in as you may struggle to remove them.
