Fixing a gap in top of front door
25 May 2020
It just needs another bead of white frame silicone sealant, I think.....probably best to cut some of the old stuff away if you can, although it’s position means that weather intrusion isn’t a problem.
John :)
Hi Karen, a piece of 14mm quad trim would finish it off lovely. It’s cheap as well. Fix it with silicone or solvent glue.
