Hello,
I'm trying to help someone with an outdoor tap kit they've bought from B&Q that they've half installed. I'm not all that experienced with plumbing but apparently I know more than them! The outdoor tap has a hose leading to a plastic female connector, as far as I can tell it's 3/4" (I'm rubbish at measuring these things and they've thrown the box with the instructions). It fitted nicely onto a spare hot water washing machine valve that was nearby which from memory are usually 3/4"?. A shame it was hot and not cold!
(I can't get the images to rotate the right way unfortunately, I've tried uploading twice, I'm blaming my phone).
They were replacing an old outdoor tap, which was connected to this stopcock valve. Again, as far as I can tell, a standard 15mm fitting (you can see the spare washing machine valve here which fitted the hose connector).
Any advice on the best way to get these to join? Can I get a coupler with a male end for the 3/4" hose connector, and a 15mm olive nut fitting on the other side? I'm struggling to pick out the right bit. Is it worth wrapping tape around both ends as well? I'm not sure I trust the plastic hose connector!
Thanks.
Thanks.
