Fixing a Lead Pipe
15 Apr 2007
London
I have a hairline crack in a lead pipe - anyone know how to fix it? Can I solder? I'd like to replace it but it would mean knocking down half a wall since it's in a really awkward position. I can't get over either end of it - since it comes out of and goes into the wall - and since the crack is on a t junction I don't think I can use any form of lead loc... help!?
You can solder it if you can get the water out.
scrape the area with a shavehook or something sharp until back to shiney lead and solder it with some stick solder if you can get it.
Not to hot or you will melt the lead :eek:
Quickest way for now is to tap the lead over with a ball pein hammer where it's split.
Gently push the lead from around the split & then tap it in & over, it will leak again but I've used this method as a temporary repair that's lasted over a year.
What he means ( I hope ) is that its physically possible to solder it.
Of course the Water Regulations do not allow soldering of lead supply pipes any more! Quite a serious offence!
The normal solution would be to replace the entire pipe function with a new copper pipe on the surface.
Tony
Hoyboy hang on....I will hunt out my turn pin and bend bolt for you and if you really want to resolder I will lend you my mole skin for a nice wipe joint.
Dont use a normal blow lamp. They are far to hot. you can also borrow my Meths mouth lamp aswell.
Am I generous or what :eek:
Stan
Meths mouth lamp :eek: you old gasfitter, you ;) primus paraffin one....meths for pre heating and drinking :eek: Bent bolt, scribing plate and dividers for T joint....oh and smudge and pipe holder:cool:
Nige you have a better memory than me old boy :)
Stan
Blacking=smudge ;) or lampblack........then cover with brown paper tied with string :eek: ....yep, taken some out like that, Works of art
No, I just didn`t mention it :LOL: :cool: like french chalk and a wire brush ;) and a M8 and a bowler hat, Pot+ladle, squirrel tail ,caulking irons un tarred gaskin, soldering irons, splash stick........etc :LOL: bobbins, bending dresser.....that`s all Plumbers can do now.....reminisce...The Corgi ****es on our legs daily :rolleyes:
