The diameter of the rose on my new fitting is smaller than my previous fitting. If I screw the fitting bracket to a joist then there will be a large hole showing when the fitting is attached. I appear to have two choices: either fill a hole in my newly painted ceiling or screw the fitting to the plaster board. The fitting weighs 2.1 kg. The ceiling is 1990 board, artexed and then skimmed over with another 5mm of plaster to hide the artex. Any thoughts, will the ceiling support the weight without using the joist?
Thanks.
Thanks.
