Hello good people,
I wish to fit a mirror cabinet in the bathroom and need some inputs.
Mirror Cabinet (approx 30 kilos, has to be hung on 2 screws 6mm i think):
http://www.ikea.com/gb/en/products/...rror-cabinet-with-2-doors-white-art-20205171/
Bathroom Wall:
Plastered and Tiled (Porcelain).
The instructions with the mirror cabinet don't say which wallplug or screw to use as Ikea simply say that depends on the type of wall (which I think is fair)
I did quiet a bit of research and understand, that bearing in mind the weight of the cabinet, I may have to go for something like a Spring Toggle plug or Anchor bolt.
My questions:
* Should I rule out long Rawlplug's ? Or If I could use a rawlplug, what type of rawl plug I have to use ?
* If I have to use 6mm Spring Toggle plug, should the hole on the wall be of bigger diameter ? If yes, what size drill bit should I use for a 6mm spring toggle plug ?
* If I have to use 6mm Anchor Bolt, same as above, what size drill bit I have to use ?
Thanks for reading.
Bathroom Wall:
My questions:
Thanks for reading.
