fixing a small leak where waste stack goes through flat roof
21 Apr 2008
Cornwall
Hiya,
I have a small leak that seems to coming in where a waste pipe comes down through a felted flat roof.
It's a rented property so i wont be re-felting, but is there a product that i can paint on around the pipe to try and stop the leak? Is there anything that can be succesfully applied in these damp weather conditions?
Thanks in advance
D
There are lots on the market, basically you want the stuff with the fibres in that sends you high as a kite.
If there is a Screwfix near you then this is just the job.
http://www.screwfix.com/prods/10990...icals/Flexacryl-Roof-Repair-Compound-Grey-1kg
Otherwise a local roofing merchants as long as its fibred usually called acrypol, sealapol etc
Even though these products can be applied in the wet, still try and do it on a dry day for that bit of extra stick! :cool:
Cheers Roofline!
That looks like the right stuff for the job!
I'll have a nosey down at the local merchant later
Cheers
D
Hi Rooofline,
I followed your recomendation and got a tin of Acrypol and used it last night,
It was as you described - nice and sticky and full of fibres - it filled around the waste stack really well and also covered all the old joins. It rained like a bugger just after i did it and i now have no leaks!!
Great recomendation, great advice and great product. Cheers!
D
