May I have the benefit of your experience please?
Once I have cut through a 9 inch solid brick wall to make a doorway, l will have to fit the supplied 130mm x 29mm door frame kit to the brickwork opening which will obviously be a little rough.
What should I use to fix the frame, nails into the mortar joints or screws and rawlplugs into the brickwork?
Googling "door frame fixing" only seems to come up with metal door frames (USA bias?)
Thank you to all the regular professionals on this site who help us amateurs to avoid costly mistakes - you really are appreciated.
