I am assembling Halo acrylic bath to replace cast iron and notice that it has two wall fixing brackets but they look more trouble than there worth. Any advice please?
Assemble bath with legs, put in position and level off. Score a line at opposite corners where bath meets wall. Move bath and fix brackets to this line. complete assembly of bath, (waste,taps ect.) and slot back in position over brackets.
The point I didn't mention about the brackets that they have slots 2.5cm long so it looks as though the screw is hardly likely to hold and you cannot get at one of the screws when the bath is in its place.
