Hi all,
I'm trying to get some information on how to fix a crooked door frame in my house.
The door is square, Ive verified this. It also looks just about correct with its constant vertical distance fomr the door frame on both sides. THe problem is the horizontal door frame across the top of the door. On the left its fine however as you look further right, the frame rises so at the immediate right hand side theres a gamr of over 1/2 inch! Above this part of the frame theres a small glass window which then rises to the ceiling.
Is there a way of fixing this without tearing the entire door frame off?
