I have some areas where i need to infill with bonding - shall i be using this to attach my thin coat angle beading to the window reveals on the new plasterboarded areas? i have heard that a dab of skim every 300mm will keep the beads in place but that sounds iffy to me?
I also have some large gaps between the boards so was going to get some joint filler to put into the gaps and then self adhesive skrim tape over (and just tape the better butt joints). Could i use joint filler to hold beads in place?
Thanks for help
Eddy
Thanks for help
Eddy
