fixing basin
30 Jun 2005
not sure if this is in the right forum, but here goes.
just installed new basin with half pedestal the problem is that the fixings supplied dont seem to be long enough to accomodate both the basin and half pedestal.
the fixings are fischer fixings with 140mm stud screws. the basin comfortably goes on but when you try to accomodate the half ped on the same fixings there is not enough thread potruding to fit the plastic bushes on.
i have tried to find longer stud screws but they are only available with a larger diameter, so unsuitable for the bushes.
bear in mind that i am fixing the basin and ped over tiles.
so, maybe you are expected to tile around it?????
any suggestions appreciated
The nylon part goes into the slots of the basin then a machine thread nut fits on after to retain the spring hooks. If the parts were all supplied together and there isn't sufficient length for this to happen have you gone too far into the wall?
Anyhow if you are trying to hard with your depth into the wall, clean the tiles and the back of the basin with meths, apply silicone assemble fast and hold in place with the screws provided. leave 24hours and you couldn't get it off the wall even if you took the screws out and jumped up and down on it, the tiles would pull off the wall before the silicone let go.
Toolsdirect sell these types of fittings seperately, pts sometimes have them, worth a look at screwfix catalogue. You might find some of better diameter to the length you require.
thanks for your replies fellas.
i probably have gone to deep into the wall, so i thought that maybe if i could get a longer stud screw, say 160mm size m10 then that would be ok. but looked everywhere and anything over 140mm is size m12. anyone know where i might get the size am looking for?
looked on screwfix, toolsdirect and pts
