Need to fix a load of 38mm treated batten to exterior brick and block walls. There is not much imposed load ... these are battens onto which will be fixed wood cladding.
Wall has earth on one side so brickwork is wet .... will fit a dpc between batten and wall to help.
Battens will vary in length depending on wall height, between 400 & 600mm high
Looking for a good fixing screw that will last, As batten is 38mm thinking of using 100mm screws ... would give a good 60mm fixing. ..... had considered 2 of these per batten ...
http://www.screwfix.com/p/dewalt-countersunk-tapper-concrete-screw-6-3-x-101mm-100-pack/49120
However on a bit of Googling saw some comments such as http://tinyurl.com/hnvntpv
That says you should not use these for batten fixing - only plug & screw method.
Anybody any comments as to best approach and what screws ...
