Anyone have a good solution for clipping cables to breeze block and other similar soft block.
It makes it easy to channel when your sds chisel goes through it like butter, but its a pig when you are trying to fix cables in place.
Cable clips generally just bounce out, though I have had limited success with the little plugs you can buy to grip the nails.
Capping is another way of course, but trying to fix that with nails can be just as fruitless and plugs and screws would take forever.
Oval conduit has some of the same problems, and you have to remember to feed the cable through before you terminate it
Am I missing a simple solution that all other sparks use, or is this just one of those jobs that everyone hates?
