I recently installed a tongue-and-groove floating bamboo floor over a concrete subfloor and almost immediately it began making an unbearable cracking sound whenever I put my foot on it.
- I left an expansion gap of 1 inch around the floor with no pinch points.
- I used PVA glue to glue the boards.
- The cracking is not at a specific point - it is all over the floor.
- The concrete subfloor curves gently over a length of about 7 metres (with the height of the curves in the middle of the room). There is little other significant unevenness - where I noticed gaps when putting the boards down I used extra squares of underlay to fill them.
- I also used a cheap 3mm all-in-one damp-proof underlay from B&Q.
- We left the floor for 6 months to see if it would settle down, but no luck...
I have 3 questions I need help with!
Is there any way of addressing this short of pulling the floor up?
If I need to pull the floor up what is the best way of doing so to avoid damage?
When relaying the floor is there a better type of glue I can use or other precaution I can take to stop this happening again?
