Fixing door of a dish washer
5 Feb 2010
We have a whirlpool dish washer, fitted with a wooden door. The door has come out, can somebody guide us to fix this up.
Rap.
Is this an electrical problem?
Wooden door? do you mean the cabinet door on your your kitchen units.
If so these can be removed by pushing the wooden door upwards, you will then see the fixing brackets used to install the doors.
They may have just worked loose and need re-fitting.
I would suggest you posted this question in either Appliances or General DIY, as this is not an electrical problem. Unless India considers wooden doors to be an electric fault :confused:
Then go to electric outside uk ;)
